주요 콘텐츠로 건너뛰기
Why my phone is restart automatically?
Why my phone is restart automatically? When battery 100 or below 50
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @rudrakshisharma
Try using the phone in safe mode and check if it works OK.
If it does then a downloaded app¹ is the cause of the problem. The trick is to find out which one.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode to check if it now works OK. When it does then the last downloaded app that was uninstalled, was the culprit.
¹ A downloaded app is one that you downloaded and installed on the phone and wasn't one that was already installed on the phone when you first got it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rudrakshi Sharma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 5
전체 시간: 97
