์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
Pc not starting properly
Whenever i try to press the start button of my pc,it dosen't work.Btw It's connected to an UPS.But when i try several times,it works.This problem gives me such headache.Sometimes It's starting, sometimes not...plz gimme proper solutions.
Thanks a ton in advance.โค๏ธโ€๐Ÿฉน
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ:
Hi @sidratulfarnaz,
What is the make and model number of the motherboard?
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
Dear Sidratul Farnaz,
Firstly, you should determine whether the motherboard is genuine or counterfeit. If it is genuine, try testing your power supply on another desktop computer to ensure it is functioning correctly. Next, check the power input of the motherboard from the beginning to the end of the line. If everything appears to be in order, proceed to check your processor (CPU), RAM, graphics card, and hard drive. When disconnecting these components, be sure to inspect the ports for any potential issues. It is also possible that the problem lies with the port or socket.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Sidratul Farnaz ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 0
์ง€๋‚œ 30์ผ: 0
์ „์ฒด ์‹œ๊ฐ„: 37
