Fan Replacement on Asus UN65H
Disassembly instructions and replacement part number for the fan. Any help would be appreciated
좋은 질문 입니까?
좋은 질문 입니까?
@rackpanels so looks like nobody has created a guide yet. It'll be up to you to do so ;-) Start off by using videos like this one or this one The fan is on the top side of the board. You are looking at the underside if you follow the videos. REmoving the motherboard is the part where we are lacking the info. It appears as if the same screws that hold the bottom to the case also holds the motherboard in the case. Some of the ports look like they are plugged into board connectors.
Just take your time and carefully look around for any wires etc. that are connected to the case. before attempting to remove the motherboard. take a look at the last image on this site You will see how the fan is mounted.
Now I did find a fan, but it sure looks like you are getting poked in the eye with the price for it. The fan number is GB0555PDV1-A / F43133 and here is another source
While you work on your awesome computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
해당 답변은 도움이 되었습니까?
Thanks for the pointers. I have something blocking the complete removal of the PCB to access the fan. Probably some sheet metal tab. I received my tools from iFixit so I can attempt again.
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 45
