주요 콘텐츠로 건너뛰기
Released in October 2020. This Acer Nitro 5 can be identified by the model number AN515-55-55M1, and the part number NH.Q7MAA.00B.
13 질문 전체 보기
Not Charging and not turning on
My laptop battery was extremely low so I hibernated it till I got home and then plugged it to charge it. It was charging. I left the laptop for about 15 to minutes and then decided to turn it own. I turned it on and it powered on and got to the lock screen for me to input password and then the laptop just went off. At that moment it stop charging and didn't come on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Without being able to look at the machine and tinker with it and the power adapter in-person, it's hard to tell.
That said, based on what you wrote I would suspect either the battery or the power adapter failing, if I had to guess.
I'd personally try a new power adapter (being careful to keep the packaging safe for potential need to return it) to see if that resolves. If it doesn't, I'd personally guess the battery was dead and needed replacing.
There's no swelling in the case along the bottom, especially where the battery is located, correct?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Babalola Allengege 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 13
전체 시간: 384
