Battery
도구
해당 기기를 고치는데 사용하는 일반 도구들 입니다. 매 절차에 모든 도구를 사용하지는 않습니다.
Background
The Acer Nitro 5 AN515-55-55M1 is a gaming laptop from Acer that was released in 2020. The Acer Nitro 5 AN515-55-55M1 is a 15.6" black and red laptop designed for gaming on the go. It is capable of a high refresh rate (144Hz) for a smooth gaming experience. The chassis has remained consistent throughout the Acer Nitro 5 line internally and externally, including this one.
The Acer Nitro 5 AN515-55-55M1 has been superseded by the AN515-55-53E5 in 2021.
Identification
The top shell and bottom of the display bezel define the device as an "Acer," and the bottom-left sticker on the keyboard deck define the device as a "Nitro 5." The model number can be found on the rear of the device on the sticker near the bottom as "AN515-55-55M1."
Technical Specifications
Operating System:
- Windows 10 Home
Processor:
- Manufacturer: Intel
- Processor Model: Core i5-10300H
- Processor Speed: 2.50GHz
- Processor Core: Quad-core
Display/Graphics:
- Manufacturer: NVIDIA
- Graphics Controller Model: GeForce GTX 1650
- Graphics Memory: 4GB GDDR6 Dedicated
- Screen Size: 15.6"
- Screen Technology: IPS LCD Full HD, LED Backlight
- Resolution: 1920 x 1080
- Refresh Rate: 144Hz
Memory:
- Memory Capacity: 8GB
- Memory Technology: DDR4 SDRAM
- Memory Slots: 2
Storage:
- Solid State Drive Capacity: 512GB
- M.2 Slots: 1
Network and Communication:
- Wireless LAN Standard: IEEE 802.11 a/b/g/n/ac/ax
- Bluetooth Standard: Bluetooth 5.0
Battery and Power Information:
- Number of Cells: 4-cell
- Run Time: 11 Hours
- Battery Technology: Lithium Ion
- Maximum Power Supply Wattage: 135 W
Physical Characteristics:
- Height: 0.94"
- Weight: 14.3"
- Depth: 10"
- Weight: 5.07lbs
Interfaces, Ports, and Devices:
- Microphone: Yes
- Finger Print Reader: No
- HDMI: Yes
- Number of HDMI Outputs: 1
- Number of USB 3.2 Gen 1 Type-A Ports: 2
- Number of USB 3.2 Gen 2 Type-A Ports: 1
- Number of USB 3.2 Gen 2 Type-C Ports: 1
- Total Number of USB Ports: 4
- USB Type-C: Yes
- USB Type-C Detail: USB Type-C port supporting: USB 3.2 Gen 2 (up to 10 Gbps)
- Network (RJ-45): Yes
Source to specifications is here.
Additional Information
Acer Nitro 5 AN515-55-55M1 Support Page
