주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Battery Connector broken, must change logic board?
I repaired the LCD but while i was re-mounting the iPod i broke all the pints of battery connector (it worked pretty well for 1 hour) Any Help? what can i do? thanks guys. I want to repair this iPod because i'm sentimentally attached to it.
Byehttp://imageshack.us/photo/my-images/694...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
ruggeromariazanolini, that is a very common thing to happen. Anyhow, there are really only two things that you can do. One is, of course, to replace the logic board. Not a very expensive or difficult task. The other thing you can try, is to get a local shop to solder a new connector onto the board. It is surface mounted, so you will need to get someone with experience in doing that type of repair. The clip is available at places like this. Either one of those repairs will ensure that you get to keep your iPod functioning. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Thanks mate. I understand, so you think is possible to change that connector(with the new one you've shown me) though the small pins are completely broken? i'm going to a tech expert right now, thanks 4 your timely response :)
ruggeromariazanolini, yes it is possible to get it fixed. Just remember that this is a surface soldered connector and requires special skills and tools. Good Luck and let us know.
Tomorrow i'll have some news about it. Thanks really a lot, you've been really kind! =)
Good Luck to you and let us know how it works out.
댓글 달기
HI the charging connector 3 path is damaged how to solve this someone recomended puting jumper but unable to find the right track
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ruggeromariazanolini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,164
