My phone is lagging
When I start the phone the it start lagging
좋은 질문 입니까?
Hi @realmec11
Start the phone in safe mode and check performance.
If it is OK i.e. no lagging, then a downloaded app may be the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall. When it works OK in normal mode, the last downloaded app that you uninstalled was the cause of the problem.
A downloaded app is one that you downloaded and installed and wasn't pre-installed on the phone already.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 5
30일 전: 46
전체 시간: 345
댓글 5개
No sometimes lagging
Najilnavas2 의
Yes i have this problem every day
Shyam 의
Auto switch off mobile app not open
Realms c12 의
Ram Nishad 의
laggings realme c11 phone
Realme c11 의
