My dryer spins and blower works, but there is no heat or error code?
Dryer is 2.5 years old. Vent and filter are clear of lint. I have checked fuse, high limit thermometer, cycle thermometer, and heating element for continuity. The thermistor has proper resistance. The moisture sensors also are good. However, no heat!
좋은 질문 입니까?
댓글 3개
@nikki84708 what exact model is your dryer?
oldturkey03 의
The dryer model is Maytag MED7230HW
Nikki 의
@jayeff Thanks - it was worth a shot. Dryer: no fault codes, ran diagnostic (no heat, steam step pooled up as water, no new error codes triggered). Continuity tests all checked out again, thermistor has resistance. No ACU error code, checked the outlet for 240. Everything seems okay, but alas no heat.
(Washer: had a fault code for large load / imbalance; last load was not unusual but will check leveling on machine - very bad squeak during wash.)
Nikki 의
