주요 콘텐츠로 건너뛰기
Frigidaire High Humidity 50 Pint Capacity Dehumidifier FFAP5033W10.
Coils freeze over and it does not drain
This dehumidifier is about 1.5 years old and half a year out of warranty. The coils started to freeze over recently. I cleaned out the filters and made sure the fan was working properly. It must be one of the sensors (I cleaned them off too since there was some dust on them). Any ideas on what could be wrong and how to get replacements parts if they don't seem to sell any? This does seem to be a common issue as I look at the product reviews now, but no one seems to have solutions. Many of these seem to break after 1-2 years
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
As you may or may not know, dehumidifiers are basically air conditioners that return air at relatively the same temperature as the room instead of cooling air. They're designed to condense moisture from a room to remove humidity and drain moisture into a pan for periodic emptying. From your descriptions, freezing coils may be due to a leak, loss of refrigerant. Most sealed refrigeration systems are factory sealed for long life, usually beyond the warranty period. Loss of refrigerant is detected by an electronic leak detector sniffing around the plumbing by a technician knowledgeable of refrigeration systems. If there are electronics used to cycle the compressor to prevent icing then electronics may be at fault. Unfortunately, only knowledgeable diyers or pros can determine where fault lies as this is usually beyond average diy repairs. Perhaps someone here more knowledgeable can help but post year, make, and model number. You may be able to search youtube videos for diy troubleshooting.
댓글 달기
답변 1개
가장 유용한 답변
Hi @ayebraun
Here's an article about the humidity control that may be relevant to the icing problem with your dehumidifier.
Unfortunately the parts lists that I can find don't mention it (or too many other parts either)
Examples of the parts lists for the model I found are the manufacturer's parts list and this parts supplier's list.
If the humidistat is the problem then I did find 3 different Frigidaire humidistat part numbers 5303296823, 5303211996 & 32736220.
Hopefully it is the first number that is also printed on the the humidistat in your dehumidifier, as spares are available online. With the 2nd and 3rd part numbers most suppliers I found state no longer obtainable.
If none of the part numbers listed above are on your humidistat, search online using the part number that is on there to hopefully find a supplier.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Alex Brown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 583
