Why is my central lock not working?
Driver side door doesnt get lock/unlock using remote
좋은 질문 입니까?
좋은 질문 입니까?
@umeshlokhande you are not telling us if it unlocks the other doors. If it does, it is the actuator in your door that has issues.
For now, we do not have enough information to narrow it down so here is the part of the SM that deals with the power looks Security And Locks Use that to narrow the issue down. Let us know what you find out.
해당 답변은 도움이 되었습니까?
if you’re meaning the button on door isn’t responding to key proximity then I’m gonna say replace remote battery and once done that you’ve gotta let it reprogramme which it will do if you turn ignition to ac and let the key displayed on ignition lights change from red to blue BEFORE attempting to turn it over…
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 29
30일 전: 158
전체 시간: 477
댓글 1개
Simular issue 2008 keyless entry swift key fob flashes indicators open and unlock but wont operate any central locking neither does the drivers side button on the door panel it make a relay type click but nothing
i have swapped the control module but does this need a computer to set the key to the new module as it does even work the indicators now
keyless start works fine
chris frost 의
