Can an iPod Touch access internet without wifi
We are disabling the wifi from our child's ipod touch by removing the antenna wire. Without connecting to the computer, is there any other way the ipod touch can connect to the internet?
좋은 질문 입니까?
좋은 질문 입니까?
Cheryl, besides the excellent points that Greg R is making, to answer your question, no. The iPod touch (any generation) can connect to the internet only through wi-fi. I am not sure if a jailbroken iPod touch can connect through bluetooth or the dock connector on the bottom. Drastic times require drastic steps :-) Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
A non-jail broken iPod touch can connect via a Bluetooth hotspot. I do this al the time. This answer is not correct.
Have you investigated whether the 'Restrictions' feature in the iPod settings will meet your need? This might be a non-invasive way to accomplish what you want.
When you enable the restrictions on the iPod, the first thing you'll be asked to do is specify a four-digit passcode which will need to be re-entered the next time someone tries to access restrictions.
By default, most (maybe all?) of the internet-using applications are turned on. You can pick & choose which you'd like to turn off, as well as limit the ability to install new apps. There are a number of other settings which can be managed there as well. Restricting Safari, for example, will remove that icon from the display entirely.
If all you need to do is turn off Safari, FaceTime and YouTube, this is a pretty easy way to do it.
Hope this helps.
해당 답변은 도움이 되었습니까?
yes all you have to do to access internet anywhere is download cydia, that will pretty much get you anywhere. once you download cydia pull it up and suck it
해당 답변은 도움이 되었습니까?
Yes. If you have a Bluetooth hotspot enabled on any other device, you can connect the iPod to the Internet via Bluetooth.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 23,346
댓글 1개
i have an iphone x
hreuhgerueg 의
