My charging port is not working
my oppo a53s charging port has an issue the charger cannot fully get inside
좋은 질문입니까?
좋은 질문입니까?
@vitin40128 check the port for any debris or bend contacts. If cleaning it or if the contacts are broken, you will need to replace it. Luckily the charging port is soldered to a charging board. It will be much easier to just change the complete board. You are looking for something like this
iFixit doesn't yet have a guide for this. Use something like this video to get this repair done.
While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
이 답변이 도움이 되었나요?
Charge is slow. Charge is slow. Charging is delayed
Change charging point
Charging not working
@ladabeshra you did not provide enough information to actually help you. I would suggest the same thing as in my original answer.
지난 24시간: 4
지난 7일: 11
지난 30일: 100
전체 시간: 3,291
댓글 10개
USB port dry and clean and reset phone ka masge a raha ha bar bar
Zidi Nuwab 의
Prajju 의
@prajju same steps as in my original answer.
oldturkey03 의
Charging problam
Oppo a53 의
@oppoa5325446 same fix as the original answer unless you have other issues that you have not described.
oldturkey03 의
댓글 5개 더보기
