Why is the water overheating
Insignia 2015 1.8 petrol
좋은 질문 입니까?
Coolant overheating may be from; a stuck closed thermostat, sealer used to fix leaks, inoperative cooling fan, blown cf fuse, faulty cf relay, faulty coolant sensor, blocked airflow from debris on the ac condenser coil in front of the radiator, etc. If you have an operating ac system, turn it on when starting up a cold engine; virtually every vehicle ac system turns on cooling fan(s) when ac is used since the condenser coil is hot from compressed refrigerant and airflow forces heated air into the radiator behind the c-coil. The fan(s) force airflow to prevent refrigerant pressures from rising too high as well as keeping the radiator from absorbing hot airflow that can contribute to coolant overheating. In addition, a faulty coolant cap may allow coolant to flow out when a pressurized cooling system is required.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 48
댓글 1개
Hi @adriansoim,
Get the vehicle's OBDII port scanned with a scantool and check what DTC code is being displayed.
This is probably the quickest way to find out what's happening e.g. faulty cooling fan operation, coolant thermostat, coolant temperature sensor etc
jayeff 의
