wifi signal strength is low and continuesly disconnect the network
wifi signal strength is low and continuesly disconnect the network how to fix?
좋은 질문 입니까?
좋은 질문 입니까?
Try using the laptop WiFi as close as possible to your network router i.e. <20 cm and check if the signal is stronger and also that the connection is stable.
If it is there may be an antenna problem with the WLAN adapter in the laptop.
Here's the servioce manual for the laptop.
Go to p.27 to view the procedure to remove the WLAN card. You don't have to remove it but this will allow you to check that both of the antenna cables connected to the card are securely connected or not.
해당 답변은 도움이 되었습니까?
Try rebooting the router
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 59
