주요 콘텐츠로 건너뛰기
Fix your iRobot Roomba e5 vacuum with these replacement part DIY repair guides. Model Number e515020
4 질문 전체 보기
Runs only short period of time
Runs only 10 minutes after charged, usually run at least 1 hr.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
There's an option to limit run time on the app setup. If you've ever used the irobot home app with this device, I'd start by making sure it's not set to limit run time in the app. If not, probably consider replacing the battery pack, which is a pretty simple task on these.
댓글 달기
답변 1개
Likely, the battery is having an issue. When it stops working, does the battery take the full time to charge? Otherwise it could be an overheating motor or something like that
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Barry Meltzer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 160
