주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad Yoga 370은 360도 힌지와 멀티터치 AES 지원 터치스크린, 모바일 연결을 위한 옵션인 LTE-A를 갖춘 얇고 가벼운 휴대용 2-in-1 기기입니다. 모델 번호: 20JH002AUS.
Device not switching on
  • Why is my PC not turning on and also not charging when connected to a power source?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I need an urgent reply 😭😭
의 공유
댓글 달기
답변 1개
@lanry you are not really telling us a lot here. Would be nice to know what you have checked and if anything has happened to this Thinkpad. Anyhow, I suggest you start with the basics for all devices and check a few things.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lanry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 18
전체 시간: 412
