주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1055 질문 전체 보기
What sorta batteries (from different phones) fit in 2016 iPhone SE.
I was wondering what other sort of batteries from different phones would fit in my 2016 iphone se i would buy the normal one but i see some batteries have more Mah which would make the charge last longer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@ummmiguessso, the short answer is none. The only battery you can use in a 1st generation iPhone SE is a battery made for a 1st generation iPhone SE. Every time a new phone comes out, the battery is custom designed to take up all available space inside, because the bigger the battery, the more mAh it can hold.
So right there is your reason it won't work; if it has more mAh, then it's bigger, and if it's bigger, it won't fit inside your phone; that's just physics.
That's beside the other considerations like the particular sensors built into the battery and the placement and type of connector to plug in; Apple uses a few different plugs and they're not all compatible. And the flex cable that leads to where it's plugged into the logic board is made to fit very carefully, so if they move that connector even 1/8" it will no longer plug in.
Anyway, there's a whole bunch of reasons why you can't use a different battery, so don't bother wasting your time looking for an alternative because there really aren't any. Over the years there have only been very minor advances in power density for Li-Ion batteries, so you may come across one that offers a small percentage increase in mAh, but if you run into the so-called "gold" batteries that claim something like double the power rating of the original, you can be assured these are scams. Like I said if you want a battery with twice the power you need a battery that's twice the size. One of our esteemed volunteers, @oldturkey03, has written a great article about those fake batteries.
The myth of the "high capacity" batteries - iFixit Repair Guide
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
UmmmiGuessSo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 48
