주요 콘텐츠로 건너뛰기
The Motorola Edge Plus is an android smartphone made by the Lenovo subsidiary Motorola
Has anyone replace the battery of a Motorola Edge Plus?
I need the battery of my Motorola Edge Plus. Can the pad on top of the battery, which i assume is for wireless charging, be reused? I'm not sure if i can get it off in one piece. I've managed to locate one for $15 (https://www.esourceparts.ca/replacement-...) but i think that's too much money. Will the phone work without it? Any advice will be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Motorola edge plus auto charge draining problem
댓글 달기
답변 1개
가장 유용한 답변
@ih8win95 yes, it should work without wireless charging. However, it is there for a reason so try to keep it intact (as much as you can. You do want to reconsider since now would be the time to change it. Once you have your phone open, do it all at the same time. No reason to have to do this over again later. The cost for that is really not to bad but I totally understand.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The battery is bloated thats why i need to replace it. If i can get it out without it blowing up in my face i'll save the charging pad and stick it on the new battery no matter what condition its in. If it works, great. If it doesn't work, oh well. I dont use wireless charging anyway.
@ih8win95 replace the battery in a well vented area since it can put out a stink if it opens up. Keep a small metal container with some sand handy. Just in case it should "vent with flame" Water and Lithium do not play together nice. Take your time, use common sense and all will be fine. Let us know how it goes.
댓글 달기
답변을 추가하세요
ih8win95 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 36
전체 시간: 633
