Replacing 1TB SSD with 2TB SSD - not being recognised
I have ThinkPad X1 Carbon 7th Gen laptop. I am trying to replace a 1 TB SSD by cloning it to a 2 TB SSD. The clone completes successfully but when I install it I get a message that โA required device isnโt connected or canโt be accessedโ. It reports โInaccessible Boot Deviceโ. I have tried various procedures recommended using a Windows 11 recovery usb drive, but to no avail. Has anyone experienced a similar problem, and if so, do they have any suggestions?
์ข์ ์ง๋ฌธ์ ๋๊น?
๋๊ธ 10๊ฐ
Hi @mjkalba,
Is the SSD shown as being detected in the BIOS storage drive menus?
If not it may be a faulty drive or not connected correctly.
If it is then something went wrong when it was cloned
jayeff ์
It is detected by thw BIOS. It can be accessed from Command Prompt mode in the Windows Recovery environment and by other tools recovery medir.
mjkalba ์
@mjkalba
Just verifying that you cloned it using cloning software and not just copied over to it from the original drive?
jayeff ์
Cloned with Partition Magic, Macrium Reflect, and Aomei Backupper Pro. Same result with each tool..
mjkalba ์
@mjkalba
Have you checked that the cloned disc is set to "active" as shown in this link?
jayeff ์
๋๊ธ 5๊ฐ ๋๋ณด๊ธฐ
