주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
I found a USB C - MagSafe adapter on Amazon. Any good?
Hello! I have a MacBook, which I have converted to a Chromebook, by downloading ChromeOS Flex. The MagSafe 1 charger I was using is badly frayed, and needs to be replaced. Will this cheap USB-C to MagSafe from Amazon work OK with my small Apple USB-C charger brick?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Actually the one showed in the pic ain't good for the magsafe 1 system. BUT, the other one "L Shaped" adapter works just perfect with the whole series of MacBooks depending on magsafe 1. How I can tell about it?
Just because I use currently not one but several of those adapters with generic "ugreen" power adapters (60-100w) with usb c power delivery and a generic usb pd cable. Don't hesitate, buy it if you still need it
댓글 달기
답변 2개
선택된 해법
Sadly no, this is a USB-C power delivery solution. It allows the newer MagSafe systems to use a USB-C charger. The MagSafe connector is also physically different it’s longer and narrower than the original MagSafe.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Do you know of another low-cost, easy alternative?
@wmf10 - There are no alternative charger. Be careful knockoff chargers often damage your system and some are so bad they can set a fire! One of my employers engineers forgot his charger in a pinch bought one at a local shop to charge his system only to have both go up in fire. It cost the company over 2 mill in damages.
That's not good, but thank you for the warning!
@wmf10 - If you’re set don’t forget to accept the answer.
Apple in newer generations did address the lack of choice, moving to a power standard with the 2016 and newer MacBook systems embracing USB-C. As people didn’t like the USB-C connection as tripping on the power cord would cause the system to tumble to the floor breaking it in the process! Apple then re-embraced the MagSafe interface!
Being the third version of the interface, all three use different voltages and control interface.
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
_nec6678 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 38
전체 시간: 456
