How do I replace the power button?
My n3dsxl is just fine except for the power button. It works when it wants to and I cant tell if its jammed or something like that. What do I do?
좋은 질문 입니까?
좋은 질문 입니까?
From your description the most likely issue is the physical button on the button board is intermittently failing. It is entirely possible that something is causing the button to stick. In either case you will need to remove the button board to check or to replace it. To remove the board follow the steps 1 through 11 of the Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement guide.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 26
