MVWB765FW1 Is spinning water off the direct drive unit
I noticed water under the machine checked for leeks none I can see. Ran the machine no clothes in it no leaks. Loaded clothes in it ran it slings water off the direct drive unit
좋은 질문 입니까?
좋은 질문 입니까?
Perhaps there's a problem with the drive control system.
Here's the tech sheet for the washer.
Run the diagnostics as described and check if any error codes are shown.
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
Jayeff
thanks for the reply but I've used the self check system, and nothing. ive check all the hoses and no leaks. ive checked the pump, no leaks no cracks nothing. it looks like water is some how leaking form the center of the tub down on to the motor/ drive unit. its not a lot and does not do it with no clothes in machine. but if you add clothes and run it it leaks down on motor and motor slings it out from under the machine
Looking at the parts diagram there seem to be two washers in between the outer tub and the gearcase, parts #11 and #15.
Maybe part #11 is worn and allowing the water to pass through from the tub.
Part #15 if worn would create other problems e.g. grinding noise etc not leaks
Found a few videos that show how to replace the tub seal but the washer doesn't look like the manufacturer's part # W11032711
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 45
