How do I change the charging port?
My little brother got a new Switch Lite and gave me his broken one, he was too rough with the port, is there anyway to go about changing the charging port
좋은 질문 입니까?
좋은 질문 입니까?
I did notice on the teardown that the charging port is literally soldered onto the motherboard (https://guide-images.cdn.ifixit.com/igi/...)
It is doable but there's always risk in soldering electronics
해당 답변은 도움이 되었습니까?
Yes, unfortunately the USB-C ports are many times more difficult to solder than the older USB ports since they went from something like 5 pins to 20 or more. From the picture it appears you would probably need a hot air station to swap out that particular port, assuming you can locate the correct replacement part.
Without some fairly specialized expertise this is a repair that, for most of us, would be better left to a repair shop.
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 50
