주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2635 질문 전체 보기
Samsung BU8500 TV screen problem white screen then flickers to black
Hello everyone.
I have been given A Samsung BU8500 TV with A screen problem would rather try to fix it instead of going to ewaste or something.
TV powers on but it's just a white screen then flickers to black screen
Have uploaded A video of the problem
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @hal_fixit
Seems as though this is a reasonably new model i.e. ~2022 is this correct?
If so then I'm not sure if the following test will work but worth a try maybe. This used to be the standard Samsung troubleshooting test on earlier models to initially determine if the problem was in the LED backlights, the power board or the mainboard
Disconnect the power to the TV, remove the back cover and then disconnect the power board - mainboard cable at the power board end only.
Reconnect the power to the TV and turn it on.
Normally if all was good the backlights would turn on and stay on. There is no display/audio as the mainboard is disconnected.
If the backlights flicker or don't turn on at all, this narrows it down to the backlights or the power board.
I can't find a decent image of the power board (BN44-00947G? I think) so I'm not sure how many backlight strips are being supplied by the power board.
The next test is to disconnect the LED backlight power cable from the board and measure the voltage on the power board backlight connector pins. Do this between the LED + pin of each feed and an Earth point (screwhead) and not between the +ve and -ve LED power feed for each strip. Check that the voltage is stable and not fluctuating to a large degree.
Looking at images of the power board there appears to be some LED reference jumper links near a connector so maybe check the voltage on it (are they LED1+ and LED1- can't tell too faint and my eyes are gone anyway). Also check for any info on the board pertaining to voltage levels as they may give some idea. Be safety aware as it may be between 150V-280V DC
Be safety aware in general as there is exposed lethal AC voltage on the power board
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for this. Going to open up the TV tomorrow and do my best and have A look. Be nice to get it working and keeping it out of going to waste.
댓글 달기
귀하의 답변을 추가하세요
Hal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 41
