주요 콘텐츠로 건너뛰기
Device and repair information for the Behringer Eurolive B212D speaker system.
Why does my speaker quit after about an hour?
My speaker works great for approximately an hour or so then stays cutting in and out then stops working completely.
Update (10/21/23)
I found that one of the leads on coil "L1" has a bad solder joint. This would most likely be why it would work for a while then cut out as the unit heated up. I will resolver and give it a go.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@bruce66667 this "speaker works great" combined with that "cutting in and out then stops" leads me to believe that this is a power board issue. Possibly a bad MOSFET or other component. Open it up and take a look at the power board Behringer Eurolive B212D Power PCB Replacement for any discolored, odd looking component etc. Post some good pictures of it with your Question. That way we can see what you see. 기존 질문에 이미지 추가하기
Behringer Eurolive B212D Power PCB 이미지
안내서
난이도:
조정
30 - 45 minutes
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@bruce66667 yes, that would definitely be an issue. Let us know if resoldering the inductor resolved the issue.
댓글 달기
답변을 추가하세요
Bruce 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 192
