주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Won't turn on
My laptop won't get turns on when I plugged in charger or plugged out. Even no indicating light turned on. When I press power button, don't get any response from the laptop.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This is a harder issue to solve. Try a different power supply for the laptop. If that didnt work, unplug the battery. A battery can short circut and cause the laptop to not do anything. You should be able to find a guide that shows you how to open up the laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rubaiyat Hiya 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 168
