주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 2월 25일에 출시된 Valve에서 만든 휴대용 게임기, LCD 디스플레이가 장착된 Steam Deck의 수리, 분해 및 문제해결 정보입니다. 모델 번호 1010으로 식별됩니다.
Screen fixed but no controls
I had a broken screen on my steam deck and ordered a new one from Ifixit. Got the screen changed with no issue but when I have turned the steamdeck back on I have no controls. The only button working is the power button. Any ideas what this could be?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Check your work. The power button is the only one that's mounted directly to the board, that's probably why it's working. . Everything else runs through cables to get to the motherboard.
Generally, I would be sure that all these cables are connected properly. Those ZIF connectors can be fussy if you're not familiar. But if no buttons are working aside from power, I would wager your issue will be with the button board cable. Even though there a variety of buttons on different boards, ultimately they all run through the same cable to the motherboard.
It's the one that connects to the back of the board in this picture. Be sure there wasn't any damage to the cable and that it's secured properly on both ends.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you For the Reply
댓글 달기
Got it sorted. Ribbon cable has come out when I put the main board back in. The small fiddly one on back of main board
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Beat me to it. Glad you got it sorted!
댓글 달기
답변을 추가하세요
Steven B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 430
