주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
Where to find replacement gasket?
Where can one find the replacement gasket?
The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide. I have not been able to find with basic search terms.
Thank you in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @kb_kb
If you can't find a replacement gasket, you may have to improvise.
Try either a suitably sized elastic rubber band or perhaps run a thin bead of neutral cure silicone sealant around the case in place of the gasket.
If using the sealant and you need to open the case in the future use either vinegar or Isopropyl Alcohol to soften it first and then pry open the case.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
KB_KB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 26
전체 시간: 403
