주요 콘텐츠로 건너뛰기
Repair guides and support for top and front loading Whirlpool brand washers.
Why does my washing machine make noise when not in use?
I woke up this morning to a strange noise coming from my laundry room. My washer seemed to be making a noise that sounded like it was slightly running (not agitating or filling with water, just kind of humming). The noise stopped when I unplugged it. But when I tried to turn it on to run a cycle, nothing happened. None of the lights turned on or anything at all. When I plug it back in, the sound starts again after about 5 to 10 seconds.
Update (10/28/23)
The noise seems to be coming from the water drainage hose. It is like it's trying to empty water from the machine but it's not turned on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Hi @moriahmedina,
What is the model number of the washer?
댓글 달기
답변 3개
가장 유용한 답변
"The noise stopped when I unplugged it. But when I tried to turn it on to run a cycle, nothing happened." >> you didn't plug it in!
"When I plug it back in, the sound starts again after about 5 to 10 seconds." >> Your water pump may be activating. If anything is activating when it is OFF, that would indicate a defective controller.
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
I did plug it back in when I tried to run the cycle. I didn't try to turn it on after I had unplugged it.
Thank you so much for the info about the defective controller. I will look into it. Thank you.
Did you ever get it fixed? Mines doing exact same thing now
@alison86293
Most Whirlpool washing machines will have a PCB schematic inside the unit for technician reference. The document should contain info telling you what pins connect to components from the controller. You can use a multimeter to determine if the water pump is activating at the wrong time.
Whirlpool has a known issue of washers making noise when off and they are fixing them for free. If you have a whirlpool…call the 800 number
댓글 3개 더보기
댓글 달기
Hi, just yesterday returning to our vacation home we discovered our washer making the same noise immediately after we turned the water back on after being away for 3 weeks. I too have model WTW4816FW3.
Since I couldn't make it stop by pressing buttons I simply unplugged it overnight. This morning I plugged it back in and after about 5 seconds the same buzzing noise started up. There were no control light indicators on, so I pressed the start/reset button for more than 3 seconds and the noise stopped. I'm currently running an empty load to see what happens next, and I will also be calling Whirlpool to check on a fix and/or warranty claim.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
1- Unplug the washing machine for 10 seconds.
2- Plug it in and wait 10 seconds. It may make the noise again.
3- Press the start button for five seconds and the noise will go away.
4- Wait five seconds and start washing a load as normal.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Moriah Medina 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 22
지난 7일: 179
지난 30일: 767
전체 시간: 9,016
