My touchpad often freezes especially when plugged in - how to clean?
When I'm using my laptop. The touchpad often freezes or very stuttery especially when I plug charger in. I suspect it's because dust / dirt piling up inside the touchpad edges, I tried cleaning up with alcohol but doesn't really helped.
Additionally, I did try to use every driver version on hp site and eventually just removed the touchpad driver and use microsoft default driver, Removing it actually make it bit better, frequency of it happening decrease but still I encountered freezing issue.
If you guys have experienced solving this, what did you do to eliminate or at least reduce the issue so it doesn't happen frequently? Thank you.
좋은 질문 입니까?
댓글 2개
Have you tried opening up the laptop, and cleaning around the touchpad, or did you just clean it from the outside?
shingle 의
I did clean it from the outside, just trying to clean the touchpad area, also tried to clean the edge while pressing the touchpad in hope of cleaning it further.
I guess then I'll need to dry disassembly it fully.
Kongg 의
