Can I put a retina display on my iMac?
My iMac doesn't have Retina 4K Display because is not 2014, so i want know if can i buy a 4K Retina Display for 2014 iMac and put it in 2013 iMac? Both have the same connector?
좋은 질문 입니까?
좋은 질문 입니까?
There are two versions of the 2013 systems
So as you can see there is no difference with the internal display, the Early 2013 and Early/Mid 2014 all offer a Native display Resolution of 1920x1080 within the internal display.
Now the Late 2015 (iMac18,2) does offer a Retina 4K display with a native resolution of 4096x2304, with a "wide color" DCI-P3 gamut, and brightness of 500 nits. By default, it runs "pixel doubled" at 2048x1152, but also can run at scaled resolutions of 2304x1296 and 1560x1440.
The 2012 through to the non-4K Late 2015 use a different internal interface than the 4K Retina systems. While they look the same the 4K connector is physically bigger (more pins) And you can’t plug in the smaller internal non-retina cable into it.
So sadly you would need to replace both the logic board and the display which is just not economical.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 22
