주요 콘텐츠로 건너뛰기
The Sony KDL-50W800C TV is a model with a screen diagonal of 127 cm, a screen resolution of 1920 x 1080 pixels, an aspect ratio of 16:9, 4 HDMI ports. 2 USB ports to connect an external hard drive. Ethernet port to connect to the internet via cable, internet connection via Wi-Fi, the Android operating system. Release date: 2015-07-02.
9 질문 전체 보기
TV late starte. Give some help
TV late start and initiate screen not seen.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@radheshyam42855 "TV late start and initiate screen not seen." clarify this by giving us more history. LAte stat cold mean it takes some time to turn on. That could be an issue with the power board or the main board. So could be the no picture situation.
First, let us know what model your TV is. You picked the Sony KDL50W800C but we need to make sure. After that, unplug the TV and remove the back cover. Now take a look at the individual boards. Check for missing, charred looking components or burned traces. Check the heatsinks on the power board. I would suspect some MOSFET (as well as bad capacitors) being the cause for that. Post some good pictures of all of your boards with your Question, that way we can see what you see.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Radheshyam Aluminium 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 21
