주요 콘텐츠로 건너뛰기
Repair guides and support for Whirlpool brand dryers.
Why is my dryer not heating up.
I replaced the heating element in my dryer and it did fine on the first load of laundry but it isn't heating up again.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
@jake98574 what is the exact model for your dryer? Besides replacing the heating element what else did you check?
@oldturkey03 the model is a WED4850BW0. the coil for the element had a break in it and the thermostat that is attached was showing it had continuity before I put it on the new element
@jake98574 can you check again and see if your heating element still shows continuity and if the thermostat still has continuity as well?
댓글 달기
답변 1개
선택된 해법
Hi @jake98574
Here's the wiring diagram for the dryer that may help.
There are two thermostats and a fuse in the heater's operating circuit so you may have to check all of them.
If they all test OK have you checked that there is 240V AC i.e. 2 x 120V AC at the wall power outlet that the dryer is connected to or that the allocated dryer fuses in the house power box are OK? The dryer needs a 240V power supply to work. One 120V supply for the motor and controls and the other 120V supply for the heater.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jake 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 272
