주요 콘텐츠로 건너뛰기
Laser printer sold by Kyocera under the Kyocera Mita branding.
How can we connect this printer to other computer remotely
I am getting unable to connect to remote networks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Given the age of the Kyocera Mita hardware, parts are probably NLA (new from Kyocera). You run into this problem with the bulletproof HPs (like the LJ 4 and 5) and the HP LJ 4000 series due to their reputation for being nearly unkillable. Even the P4015 is as bulletproof as the 4000/4050/4100/4150/4200/4250b was, as it's basically the same engine with a newer toner. The solution with those is to have the card installed in the printer but keep a spare EIO card or two around as HP no longer makes them.
However, this works better with HP because of how many of them are sold, so there's a surplus of printers and accessories like cards. This isn't the case with the Kyocera you have.
As @jayeff pointed out, the OEM P/N for the Ethernet card is FS-21E. I looked on eBay since that’s the key place we get the HP EIO cards, and I didn’t find any, but your best bet is to keep looking and buy one as soon as it comes up.
You're more likely to have better luck making a "print server" out of an old Windows or Mac PC, like a surplus USFF PC with an 8th/9th gen Intel process or similar Ryzen 5. You can also see if you can find a USB print server.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi @getanehabinie
Has the printer got a network interface card installed?
If not then search for Kyocera FS-21E (supplier example only), to find suppliers that suit you best. They're not cheap
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Getaneh Abinie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 407
