주요 콘텐츠로 건너뛰기
Canon MiniDV camcorder with 18x optical zoom and 360x digital zoom
2 질문 전체 보기
How can I fix my black screen on my Canon ZR60
My Canon ZR60 has a black screen and I heard that it might have something to do with the CCD but I have no idea how to fix it. The camera also records audio just fine its just there's no picture playing when I press record.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @cvez1079
Can you view your recordings when you connect the camcorder to a TV?
If you can see your recording on the TV then it may be just a problem with the LCD screen in the camera.
When trying to view a recording in the LCD screen (I realize that you can't see anything on the screen) try shining a flashlight at an angle close to the LCD screen and check if you can see any images on the screen.
If you can see images then it is a LCD screen backlight problem or a screen backlight power supply problem from the motherboard.
If you can't see images then it might be a LCD screen and backlight or motherboard problem.
Since you can see images OK on the TV then more likely it is a LCD screen problem.
If you can't see your recording on the TV then most likely it is a lens or motherboard problem.
Here's the service manual that will help.
It has the disassembly procedure (for the LCD unit see p.5-14), the parts list and schematic diagrams as well.
A quick search online for the LCD unit showed no results for suppliers. You may have better luck.
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
cvez 1079 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 34
전체 시간: 174
