주요 콘텐츠로 건너뛰기
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
UMD laser does not turn on regardless of drive
The laser on the PSP 1000 doesn't turn on but its spins, the laser moves and tries to focus, I except its an issue on-board. I don't want to replace the board, instead try component level fix. I understand their are tons of components to check along with way but what is the most common point of failure for this specific issue.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@kickflipa180 there really aren't any common points for this, The most common issues were Firmware issues. Check the PSP forums for that.
After that, you can check your motherboard for any damaged, missing or charred looking component. Post some well focused and large enough images of your motherboard with the Question. That way we can see what you see and maybe identify an issue, 기존 질문에 이미지 추가하기 Pay particular attention to componets around CN9501 and IC9501 and 9502 and CN9503
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
After your mention of firmware being a common issue, I tried my best efforts to check if that is indeed the issue and IT WAS! Thanks for setting me on the right path friend :)
How ? What did you do ?
Hey KickFlipa180 3-343 did you find your fix?? Having the same problem would appreciate ANY help!!
댓글 달기
답변을 추가하세요
KickFlipa180 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 25
전체 시간: 653
