Philips 55pos9002 TV doesn’t turn on, no led, no nothing
So when I measure input power to power board I get 220v I get 12v to the main board but tv doesnt turn on and no standby led/light??
좋은 질문 입니까?
좋은 질문 입니까?
No standby LED is usually due to a main board problem if the power board standby voltage is OK.
Here's the service manual.
Go to p.37 Sect. 8-2-1 AC Input and check the power circuit is OK (see p.38 & p.39 as well)
Hopefully this is of some help.
So all the components circled aren't there??
If so then the schematic doesn't match the board
(click on image)
해당 답변은 도움이 되었습니까?
This is golden! Thank you! Refresh my memory though where do I measure the SB voltage? 🙃
I think it might be the 3.5V on pin 1 of CN9101 see p.39.
Shouldn't it be on p.47? I'm not sure where to measure though. Thank you in advance for helping :)
My mistake, I just saw 55" and not the rest i.e. not 9002 ;-(
I don't know Philips all that well but was wondering if it is the ACD lead on pin16 CN9101 (also on pin1 of CN9103 (but it shows "not connected" so maybe it is a test connector point).
In other makes of TV ACD means "AC Detect" but maybe not Philips. I don't know.
I also don't know what its voltage value would be but it shouldn't be >12V I think
Okay I’ll try a few different things. If it is the main board do you have any suggestions what to look for there? Again thank you
해당 답변은 도움이 되었습니까?
If i measire between C9912-C9913 I have 230V AC but between D9901-D9902 I habe 0V
Looks like it might be an updated board or at least a slightly different one.
The manual shows it as an A 715G 8886.
Is this number printed on the board or something else?
it's bad enough that the Standby circuit has been deleted from the diagram but if it is a different board then this makes it very difficult.
With regards to the board I would go with the mainboard first given that the other voltages seem to be OK and also that there appears to be no obvious problems with the components on the power board i.e. no burnt out or heat stressed components or board damage
Maybe try to source a board from suppliers who accept returns for only a small restocking fee so as to minimize the cost to you if it isn't the problem and it is something else.
It is 715G8886 I’ll try to order a mainnoard and then I’ll see. Thank you for the help and I’ll @ you if I have further questions 😁
So when I disconnect the main board I get Zero reading on every pin on XP810 but not on 18V/12V I have 5v on both even after a looong time disconnected from AC. Also there is no sound or the filter capacitors do not charge up at all they are 0V.
해당 답변은 도움이 되었습니까?
So there's no stb voltage on xp810 when the AC is connected but the mainboard cable is disconnected, is this correct?
If so then this may be right. Older Samsung TVs do the same except when you do this their backlights turn on but the newer models don't but you still lose the voltage on the stb lead.
To me and this is a guess I don't think that the power board is working OK but without a schematic I don't know.
You originally said that there was only 9V on the 12V lead so I'm thinking that there's a problem with the power board not supplying the correct voltage.
The 12V/18V going down to 5V when the AC is disconnected is probably residual capacitor voltage
Yes, exactly. Yea I figured the residual capacitor voltage but felt a bit strange after 8h it's still there :) I ordered a new PB so we'll see. Otherwise I'll be here asking :D thank you for your input.
24 시간 전: 0
7일 전: 13
30일 전: 60
전체 시간: 546
댓글 8개
@jayeff
Hi I fixed the phiips tv but now im on a sony. Do you know what ”SOC Muffin problem” is??
Ambjörn Eriksson 의
@ambjoerner60296
I don't know.
SOC can mean system on a chip so maybe the Sony SOC is code named "Muffin".
Makes some sort of sense to have a "computer" run a TV especially if it has Android as an OS as some have these days.
What is the model number of the TV?
jayeff 의
@jayeff
Its a sony 55x8505c
Ambjörn Eriksson 의
@ambjoerner60296
According to the service manual there are 2 SOC chips in the TV - see p.178
A lot of the troubleshooting flowcharts point to the "muffin" soc IC1000
So once you determine which SOC is IC1000 then try changing the board that it is on as you won't be able to change the IC
jayeff 의
@jayeff
Hello old friend I have a question :D
I have a Hisense 65A7KQ that only shows the boot logo a second then turns of ish. It looks like it shows a green then red then green image but without backlight then turns off. When i measure the outputs when in stb, its strange the 12v are 9v and the stb is close to 0 and when i press the on button they all drop lower. I have power to the leds. Also the filter capasitors (82uF, 450v)x2 are ticking like 3 tick per second very low sound when pressing "on".
What do you think? Is it the power board or can it be the main board. It can be the leds but I don't know I get a feeling they work.
Regards
Ambjorn Axell
Ambjörn Eriksson 의
댓글 3개 더보기
