Lights flickering u it also squeaky
Unit works but lights are not steady. Flickering. Also squeaky
좋은 질문 입니까?
좋은 질문 입니까?
@stevene74440 could be an issue with the collector rings.
There are might just be some debris, i.e. corrosion, loose solder joints etc that could cause this. I would suggest you start looking at this. Since we do not see what you see, and going by your description alone, I suggest you take the top of the carousel and check things out. You can always post some pictures of what you are looking at etc. with your Question,. That way we can see what you see. 기존 질문에 이미지 추가하기
I am sure there are different variants of the Carousel but check this video to work on it. Time to fix this quickly. Santa is getting ready!
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 36
