Have you tried using a different, known working, compatible USB cable between the computer and the keyboard and checked if that worked, you didn't say?
@jayeff I tried everything factory, resetting my PC reinstalling drivers taking all my key cap off my keyboard cleaning it everything works. It just does not type at all and LED are all not the same I just got this keyboard please help!!!!!!!!!
Yes, it was working before and it automatically changed a couple keys to a different color and it locked up and I couldn’t do anything. I just need to unlock it. It’s so hard. I tried a different USB cable and try to plug it in to a different PC and same thing happened $300 down the drain
Hi @noxfnl
jayeff 의
noxfnl 의
@noxfnl
You never mentioned using a different USB cable, rather than the one supplied with it (if there was).
If possible try connecting to another computer.
If still no good, since you just got it, take it back and get a replacement.
jayeff 의
@noxfnl
Was the keyboard working before?
If not, just verifying that you connected the USB cable to the correct USB port on the keyboard?
One is for the keyboard and the other is just a "pass-through" allowing you to connect other USB devices to the PC
Here's how to post images in your question
기존 질문에 이미지 추가하기
jayeff 의
noxfnl 의
댓글 7개 더보기
