주요 콘텐츠로 건너뛰기
14" - Core i3 2310M - SUSE Linux Enterprise Desktop 11 - 2 GB RAM - 500 GB HDD
18 질문 전체 보기
Laptop not booting, fan spin for a few seconds then stops...
I left my laptop in sleep mode for a few hours but when I came back. It wasn't Laptop not booting, fan spin for a few seconds then stops again and again with no display.I removed the battery and drain all the power.but didn't work.
Then I unplugged the charger and the drain the power on motherboard without battery. But it is also not working.
I cleaned the ram but it also not worked.
Please help me.
I have important assignments to do.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @tcgaming360
Try a full power refresh and check if that resolves the problem.
Here's the procedure:
a). Disconnect the charger (if connected) and then remove the main battery from the laptop.
b). Disassemble the laptop and disconnect the RTC coin cell battery from the motherboard.
Here's the maintenance and service guide for the laptop that will help as you have to remove the motherboard to do this. Go to p.81 to view the procedure to remove/replace the RTC coin cell battery.
When the battery has been removed, measure its voltage. If it is <2.5VDC or if the battery is >5 years old, replace it. The battery spare part number is at the top of p.81. Search online for 646132-001 to find suppliers that suit you best.
c). Reconnect the RTC battery, reassemble the laptop, reinsert the main battery, reconnect the charger and check if the laptop turns on OK.
If it does there may be a message saying that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default settings. Once the date and time have been adjusted, the message won't appear the next time that the laptop is started. Also any user definable BIOS settings, that were changed by you to suit whatever operating requirements you had will have to be changed back again as well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
tC Gaming360 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 20
