Why won’t it close when temperatures are below 50
When outside temps are below 50, our Craftsman garage door will only close if holding the wall button down. We have made sure the connections are good and there is nothing blocking the sensors. Is there any adjustments we need to make in the housing until?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi @ritarawls,
What is the model number of the garage door opener?
Does the motor have "down" and "up" adjust screw? You could increase the down setting to help it close.
Craftsman part no: 045ACT. FCC ID: HBW7675
Hi @ritarawls
Do you mean that it won't operate when using the remote control unit to open/close the door when the temp is <50°F?
If so have you tried replacing the battery in the remote control unit?
When it starts to get cold metal contacts and also batteries if they a low are not as effective.
Just to eliminate the remote as the problem, check/change the battery in the remote.
댓글 달기
