How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
좋은 질문입니까?
좋은 질문입니까?
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
이 답변이 도움이 되었나요?
It does not appear to be enough room to use the pin driver.
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 2,182
