Why does my phone only stop at the logo when I turn it on?
Why does my phone only stop at the logo when I turn it on? and it won't continue to the home screen, is this an LCD problem? or something else?
좋은 질문 입니까?
좋은 질문 입니까?
Hi @furqonainun
You didn't specify what model the phone is, but try starting the phone in safe mode and check if it starts OK.
Hopefully the method shown in the link is applicable to your model as well.
If it does then a downloaded app¹ may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one, and test the phone in normal mode between each uninstall to check whether it works OK or not. Once it does then the last downloaded app that was uninstalled, was the culprit. A downloaded app¹ is one that you downloaded and installed on the phone and wasn't pre-installed already.
해당 답변은 도움이 되었습니까?
Possible firmware corruption, this means you may have to flash the firmware using odin and the appropriate firmware for your make and model of phone from https://www.sammobile.com/firmwares/
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 24
