주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
installing a new blade
How to install a new blade on a Murray Lawn Mower model 20507x99c
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
the blade is attached to the engine via an adapter and a bolt that holds in onto the crank. Use either your own strength, or have someone hold the blade while you loosen the bolt on the bottom. You can also use a block of wood between the blade and the deck to prevent the blade from turning.Be careful that nobody gets hurt, use gloves or a rag to hold it. The tool to use would be either a box wrench or a socket. Sometimes those bolts are pretty tight and may require some extra torque to loosen. Hope this helps.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Miike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 487
