Why its give me Black screen with blue edges and vice versa every time
Black screen with blue edges and vice versa every time I turn it on
좋은 질문입니까?
좋은 질문입니까?
Hi @bx44
The power board seems to be OK as it turns on and there's backlighting. You could always inspect it for any obvious component damage e.g. blown capacitors or heat stressed components etc.
I think though that there's a mainboard problem.
Here's a teardown guide that shows how to disassemble the monitor that may help.
Try replacing the mainboard (supplier example only) and check if that resolves the problem.
If you decide to do this, verify that the board you order has the same model number or part number as the original. Usually this is found either printed on the board or on a sticker on the board
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 153
댓글 2개
Hi @bx44,
Can you view the monitor's OSD menu screens OK?
Have you tried using each signal input port i.e. HDMI & DP?
jayeff 의
@jayeff It shows the same thing no matter how much I connect it to any device and it also does not show the OSD menu of the monitor
Bx4_4 의
