주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
seeking enclosure for SSD from MBP early 2011?
Hello - I have an early 2011 MBP that has a 1tb ssd upgrade, I would like to remove the ssd and use it as an external drive, but not finding a compatible enclosure, is there one? I found this but it seems to be perhaps only for the SATA drive being removed in the upgrade... MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit --thanks much!
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade kit. 이미지
제품
$72.99
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The case is designed for a 2.5” SATA drive not the blade SSD if your system has that.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
oops - Thanks Dan, I thought this one was an SSD but just pulled it out and it is a SATA. so perhaps it will work?
댓글 달기
답변을 추가하세요
Ali-A. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 106
