주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 5 스마트폰 수리 안내서 및 설명서입니다. 2020년 10월 15일 출시. 모델 번호: GD1YQ, GTT9Q
Pixel 5 antena replacement alternatives
My Pixel 5 detects my sim, but no signal at all on both my physical and esim after a minor water damage. WiFi works, I just can use the sim because it shows no signal at all. After some research I suspect the antenna is damaged, are there any alternate antennas that I can replace it with?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
I just can't* use the sim because it shows no signal at all
@russellpeiris
Have you fixed the water damage?
Yes, the water was removed, and some components in the charging area was cleaned, it seems the antennas are not damaged, the technician suggested it might be an issue powering the signal, I'll be handing over the phone to him for further inspection (inspecting the ic and stuff)
same story here after water damage , mine also don't wanna open cameras anymore ,modem is probably most sensitive and most exposed on the board
댓글 달기
답변 1개
Hi @russellpeiris
It seems the answer is your antenna is not powered due to water interference/damage
you should replace the cable to the antenna
let me know of any further developments
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Russell Peiris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 317
