주요 콘텐츠로 건너뛰기
Repair guides and support for top and front loading Whirlpool brand washers.
426 질문 전체 보기
WTW4715EWO goes all the way to spin cycle and doesn’t spin. It resets
WTW4715EWO Model number goes all the way to spin cycle and doesn’t spin. It resets back to wash. I then have to dial to drain and spin to finish each cycle. I replaced the springs. Nothing. Did you figure out what it was?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @lauramiles
Here's the tech sheet for the washer.
Run the diagnostic tests as shown on p.2 of the guide and check if any error codes are displayed.
On p.3 there's the Fault/Error Code Display Method chart that shows how to interpret the status LEDs to know what the code is.
The fault error code and description for the codes are found on p.6→p.7.
If there is a faulty part that needs replacing, here's a parts list that is useful.
Locate the wanted part in the parts diagrams to find the manufacturer's part number listed with the part. Then search online for the manufacturer's part number only to find suppliers that suit you best.
Hopefully a start to find out what's wrong.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Laura Miles 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 18
