Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
좋은 질문입니까?
좋은 질문입니까?
Please refer to my earlier post here.
Included are images of correct screw length needed.
Good Luck.
이 답변이 도움이 되었나요?
Hi, look carefully at this thread
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
이 답변이 도움이 되었나요?
check connector #7, place a tape on it just to make sure it's connected properly
이 답변이 도움이 되었나요?
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
이 답변이 도움이 되었나요?
[링크된 제품이 누락 또는 비활성화 됨: IF182-023]
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 12,044
