주요 콘텐츠로 건너뛰기
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
18 질문 전체 보기
New battery wear level 19% in a day!
I brougt a new battery for my laptop, it wear level in hwinfo was 0% the first day and only after 2 charges it is now 19.2% in just two days.
Should I return it and get a new one?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @mohdafzal40548
Did you calibrate the new battery after you installed it?
Fully charge the battery and then run the laptop until the battery level drops to 10% and then recharge it again to 90%. Do this twice and then check if it holds its charge better.
If still no good it may be a faulty battery.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
The battery need calibration? How is that done? I tried charging the battery and draining twice. The Laptop last for 3-4 hours.
@mohdafzal40548
Was it an OEM battery or just a compatible one?
I would get a new one given the rate of discharge that occurred.
댓글 달기
Check if it's a OEM battery.
If it is not then that will be why it keeps going flat, unless it's faulty.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mohd Afzal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 117
